First Post, so play nice
I have a new Mercury Cooker which has had it's gas line fitted but now needs it's electrics hooked up. My electrician has hooked up a seperate line box which is wired into a 45amp fusebox cooker switch.
I now need to wire the cooker to the line box. I have some 6mm heavy duty 50amp cable, just need a few pointers.
I have some images here:
Cooker point
Wall Line Box
Wire
Hopefully you can all see these
My electrician had hoped to connect everything up himself shortly after the cooker was delivered. But he has nearly sawn his fingers off in a rather nasty hedge trimming accident and cannot do the work I wanted.
He is obviously going to check off my handywork, but I wondered if anyone on these boards could help me here on the right connections.
Great forums by the way and glad I am now a part.
Thanks in advance.
___________________________________________
lynda, moderator
edited to correct image links
Cooker point
Wall Line Box
Wire
Thanks in advance.
lynda, moderator
