IVE RECENTLY REPLACED AN ELECTRIC SHOWER OF THE SAME WATTAGE AS THE OLD ONE, AFTER ABOUT A WEEK ITS TRIPPING OUT EVERY TIME AFTER ABOUT THREE MINS ANY IDEAS????
jonesey1 said:ITS TRIPPING OUT EVERY TIME AFTER ABOUT THREE MINS ANY IDEAS????
after looking closer it looks like the fuse needs changing as its a 32a and says in manual for a 9.5kw it needs a 45a would that stop it??? also it only trips when on the higher setting it works fine on the lowerSpark123 said:PLEASE DON'T SHOUT - turn caps lock OFF.
What is tripping, is it an MCB or an RCD? What size shower? What size MCB?
jonesey1 said:IVE RECENTLY REPLACED AN ELECTRIC SHOWER OF THE SAME WATTAGE AS THE OLD ONE,
Taylortwocities said:You MUST put in a larger cb if that is the case as the cable will catch fire if you try and put 45A through it.
Taylortwocities said:too much Merlot again.
