sparkinthecamp
Joined: 29 Sep 2006 Posts: 1 Location: Edinburgh, United Kingdom Thanked: 0 times
Posted: Fri Sep 29, 2006 7:24 am Post Subject: low flow rate and fluctuating pressure |
I have just had a new kitchen installed. My shower is now acting differently. The temperature is going very hot and then very cold. also when the shower is adjusted to a cooler temperature the low flow light comes on.the pipework under the kitchen sink has been altered.The mains feed used to leave at right angles now it rises verically and then returns to floor level prior to leaving at right angles.Is this part of the problem? the pipework is 22 mm. |
Agile
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 191 times
Posted: Fri Sep 29, 2006 10:14 pm Post Subject: |
Was the plumbing in your new kitchen fitted by a plumbing professional?
If so then the Institute of Plumbing has a complaints procedure!
If not then you can complain to the Polish Embassy but this may not get you very far!
Tony |
ChrisR
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Sat Sep 30, 2006 5:30 am Post Subject: |
More info needed. What shower etc- electric? |
