DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
mortice lock rebate
This topic originated from the How to page called Mortise Lock
Click here to return to the page called Mortise Lock.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
strat789
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 23, 2006 7:53 pm    Post Subject:
mortice lock rebate
Reply with quote Thanks
I have a two doors (paired) that are rebated.
I wish to fit a 3 inch (76mm)sashlock (mortice lock) When the rebate sets state \\\"..sizes available are 13mm, 25mm\\\"... Which dimension does this denote exactly?
FYI the doors are 44mm thick; rebate is 10mm (from the edge of the door); the rebates are half the thickness of the door (22mm)
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
noseall
from United Kingdom
Thanked: 73 times
PostPosted: Mon Oct 23, 2006 9:31 pm    Post Subject:
you can buy a mortice lock/latch set specifically designed for rebated doors e.g external french doors.
is this what you have?
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 24, 2006 7:37 am    Post Subject:
You can either buy the Rebated sets mentioned above (but check these are 5 lever British Standard rated), or use a British Standard lock with a rebate set. Also consider using surface or mortice bolts, mounted top and bottom on both doors to provide extra security and strength. If outward opening, then hinge bolts should also be used to prevent the hinges being cut and the door lifted out.
Back to top
 Alert Moderators
strat789
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 24, 2006 12:38 pm    Post Subject:
Thanks for the replies. I don't think I made myself clear...I think it maybe terminology (the lack of it on my part)
I bought two 6'6" x 2'9" x 44mm doors of solid engineered oak construction. ..to replace existing inward opening double doors.
The door opening is 65" wide ..so the supplier rebated them to produce paired doors for this size opening. The rebate is 10mm (from the edge of the door); the rebates are half the thickness of the door (22mm)
There are two problems that I would like to resolve:
Given the above I want to fit a 76mm sashlock (eg Union 5 lever sashlock) with a rebate set...what size rebate set (13mm 25mm etc) do I require?
The other problem is ..I want to fit a flush bolt into the edge of the non-opening leaf, so that they're concealed when closed (and more secure)
I cannot find suitable narrow flush bolts to fit into the rebated edge...without hacking a piece of the rebate out and ruining the look. 19mm bolts seem to be the thinnest available.
The alternative is to use Chubb bolts top/bottom ...but they wouldn't look as good ..since they would be visible on the inside of the door stiles. Any ideas??
Thanks for your help it's much appreciated.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
fitting a fire door to an old frame - rebate too small 3 1020 Sun Aug 12, 2007 10:55 pm
wood window frame DG rebate size? 3 700 Tue Jun 07, 2005 12:12 pm
Which lock? Mortice self deadlock.... 5 440 Sat Sep 06, 2008 7:36 pm
3 lever or 5 lever mortice lock 4 500 Tue Aug 26, 2008 10:30 pm
Victorian mortice lock with a step - can get? 2 180 Sun Jun 21, 2009 12:10 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
