The shower is an 8.5kw shower. It's only about 3 months old and has been working fine until Sunday.
When I'm using it, it runs fine for 2-3 minutes then the water stops and the power light goes from bright orange to dim orange.
The customer services team said to check for loose connections so I did. There was a connection on top of the element that needed a full turn but everything else was ok.
The isolator switch also needed the connections tightening and after this it worked fine again...for a day...now I leave it for a while, come back and the same thing happens. I checked it about 10 times today...
Any ideas? Triton will send out an engineer but if it turns out to be something other than the shower I'll be paying their fee, so just want to make sure it's not something else first. (My dad fitted the shower, the other one wass 8.5 kw so only replaced like with like).
Cheers.
Cheers.
