DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Mira shower no hot water
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
davphi338
from United Kingdom
PostPosted: Fri Dec 22, 2006 5:04 pm Reply with quote
I have a Mira shower that has suddenly decided not to give any hotwater. The shower is connected to a shower pump but I know the pump is OK because the shower in the ensuite is OK and it connects to the same pump.
The pump comes on when the temp is set to cold and there is water flow but when I move the temp to anything but cold there is no water flow at all.
Is there anything I can do to the shower to rectify this fault or is it beyond repair.
Back to top
 Alert Moderators
leakydave
from United Kingdom
Thanked: 65 times
PostPosted: Fri Dec 22, 2006 8:30 pm Reply with quote
what sort of 'Mira' shower is it?
Back to top
 Alert Moderators
peo11
from United Kingdom
PostPosted: Sat Dec 30, 2006 9:10 am Reply with quote
Believe it or not my mira shower has developed the same fault.
I have a mira 88 mixer valve.
I know that there is a seal kit available but how do you get the front plate off the mixer valve?
Back to top
 Alert Moderators
davphi338
from United Kingdom
PostPosted: Sat Dec 30, 2006 2:17 pm Reply with quote
Mine was a Mira Excel, I took it apart as much as possible but the actual valve unit seemed to be a sealed unit.
I installed a cheapo replacement to get the shower working until I renovate the bathroom properly.
Back to top
 Alert Moderators
peo11
from United Kingdom
PostPosted: Sun Dec 31, 2006 3:13 pm Reply with quote
Decided to bite the bullet and try to fix the problem.
Seal kit obtained from plumbase.
Had already obtained replacement instructions direct from Mira (visit their website, very helpful people).
Needed heat to get cover assembly off along with large stilson wrench and a hammer.
Replaced all seals and put it all back together and guess what? still no hot water coming out when shower head lifted up.
Needed to replace seals anyway as there was a leak.
Removed shower head and held hose in the air, hot water came out when fully hot selected. Cleaned shower head holes with a pin. Tried again, hot water Hurray icon_razz.gif icon_razz.gif icon_razz.gif
Tried shower myself first in case of any problems, felt great.
Hope this may help any readers.
Peo11
Back to top
 Alert Moderators
bab
from United Kingdom
Thanked: 7 times
PostPosted: Sun Dec 31, 2006 3:24 pm Reply with quote
Dont think ya can do much with em except replace. would check water flow out of body with cartridge out 1st to elininate no supply. u never no might be a check valve somewhere. is there 1 on the cartridge inlet. (white ball)
Back to top
 Alert Moderators
soul-man
from United Kingdom
PostPosted: Wed Nov 14, 2007 5:16 pm Reply with quote
I have been struggling with this problem for many months. Talking to Mira techies and getting nowhere.
Here is the answer though.
I was advised to check the strainers to see that they were clean and clear to allow the water to flow. These are located in front of two checkvalves situated on the Mira Aquations unit at the bottom at each side. Undone by a largish allen key, these checkvalves have the strainers delicately held in place by rubber seals at their tip. However it was not the strainers that were at fault but the checkvalves themselves, these were stuck closed. It was this that made my Mira shower fail to function not the strainers.
It would seem that not even Mira knew of this problem and I think this may be a design fault.
I do hope this of some assistance in the future.
Soul-man
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Mira Shower and water pressure 6 10220 Tue Feb 21, 2006 10:46 pm
Mixer shower (Mira) and hot water temp 2 260 Mon Feb 22, 2010 9:18 pm
Replacing an old mira shower with bottom right water/elec 5 80 Fri May 02, 2014 2:31 pm
mira electric shower , no water coming out of the shower 9 8640 Sun Jun 12, 2005 7:45 pm
Feroli Modena 80E Boiler, Mira 415 Shower, No hot water 2 340 Sat Jun 05, 2010 9:32 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
