Joined: 31 Dec 2006 Posts: 22 Location: Staffordshire, United Kingdom Thanked: 0 times
Posted: Sun Dec 31, 2006 12:00 pm Post Subject:
Combi boiler and cutting off water supply
Hi
I want to install new bath taps, but have no issolation valve that I can see on the pipes meaning I have to turn off the supply from the mains.
Normally I would be happy to do this, but I have just had a new combi boiler fitted and am worried if I cut off the supply that it may run dry, cut off or do something I cant fix myself.
Joined: 24 Jul 2003 Posts: 18662 Location: London, United Kingdom Thanked: 62 times
Posted: Sun Dec 31, 2006 12:09 pm Post Subject:
No it's a separate sealed system.The filling loop is supposed to be left removed, though few are, but it will have two taps and there's a non-return valve anyway.
Posted: Sun Dec 31, 2006 12:13 pm Post Subject:
Well I am confident now then that I can crack on with the work, I thank you Chris for your time and speed.
I was going to ask about the 2 valves on the boiler pipes (I have 6 pipes but 2 have a cut off valves similar to a washing machine pipe 1 red and 1 blue) and wether I have to close them, but will see how I get on!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
