DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
drain noise & smell
This topic originated from the How to page called Drainage Systems
Click here to return to the page called Drainage Systems.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
larigo
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 17, 2007 8:29 pm    Post Subject:
drain noise & smell
Reply with quote Thanks
the kitchen extention single story is nearly completed but now I have access to the kitchen I can hear from the main waste drain pipe going into the floor noise from the drain system. i.e. if someone uses the shower upstairs. however I also hear noise from the pipe if the next door neighbours turn on taps etc. the pipe is about 100 mm diameter (brown) at the moment there is no covering on it with only a single 40 mm pipe running into it. I know from watching the building going on the pipe runs about 3.5 meters towards a man hole which the builders had to put in. (the man hole is outside the extention.) the drain between the houses is shared. Main thing is how to get rid of sound and do I need to get the builders to change something add something etc. There does not seem to be smells coming from the pipe. I presume this is becuase the man hole is right by the main venting stack pipe thingie on the side of the house. Any help or suggestions.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
solo
from Albania
Thanked: 0 times
PostPosted: Sat Feb 17, 2007 10:53 pm    Post Subject:
Buy some cotton wool balls and stuff them in yer lugs.
Back to top
 Alert Moderators
larigo
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 18, 2007 9:38 am    Post Subject:
noisey drains
Thanks but I want a long term solution not just a quick one. And no I dont want to cut my ears off or anything. Anyone with a real solution please let me know.
PS last night it also started to smell.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Smell from bath drain 3 720 Tue Mar 14, 2006 4:07 pm
Drain Smell After replacing WC 4 860 Thu Sep 01, 2005 11:01 pm
Drain smell 7 4380 Mon Jul 23, 2007 11:12 am
stinky smell from kitchen drain 4 2220 Sun Apr 24, 2005 6:21 pm
Kitchen drain smell 5 520 Fri Feb 08, 2008 8:27 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
