DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Waterproof bathroom/kitchen sealant easier said than done !!
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
davegriff
from United Kingdom
PostPosted: Mon May 03, 2004 7:29 pm Reply with quote
I am having an absolute goddawful nightmare with sealing my bath and my kitchen sink with that white waterproof silicon sealant stuff
My bathroom currently looks a complete mess, and I have just finished attempting to seal a tiling shelf I had next to my sink in the kitchen.
Both times, I just could not get the selant to look half decent.
I beaded it on, then used a speacial tool to try and smooth it out.
Both times, all I got was a complete mess, my hands covered in sealant, and bits of sealant everywhere.
This has been the worst job I have yet had to do, and I'm getting really annoyed that I can't seem to get it right.
Can anyone
1 - Advise me on the best way to get rid of the botch job in my bathroom, and
2 - Let me know how the pro's get it so right ?
I am at the end of my tether.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Mon May 03, 2004 7:32 pm Reply with quote
Masking tape on both side and use a little amount of sealants then wet finger & run over the sealant with light pressure, remove masking tape straight away then run wet finger over it again gently.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Mon May 03, 2004 8:01 pm Reply with quote
also only use genuine SILICONE sealant
Back to top
 Alert Moderators
dog2
from United Kingdom
PostPosted: Tue May 04, 2004 3:06 pm Reply with quote
dont put to much sealant on then get some washing up liquid and put a little bit on a clean surface then use that on your finger it should be easier
Back to top
 Alert Moderators
emailrob
from United Kingdom
Thanked: 1 time
PostPosted: Fri May 07, 2004 11:12 am Reply with quote
davegriff, I can completely sympathise with you. I have gone through the same thing with my bath. In the end I took off the new sealant as it looked cr*p, and started again. Second time was much better.
Useful to fill the bath with water a few hours before you do it, so that the sealant does not come away from the bath when full.
Some advice above was to use less sealant, definately good advice! When you cut the tube on silicon only cut a fairly small hole in it, maybe 5mm or so. When you smooth it with a wet finger, it will not go everywhere and make a complete mess (I know from bitter experience!!)
Best of luck
Back to top
 Alert Moderators
Mr Ben
from United Kingdom
PostPosted: Sat May 08, 2004 8:01 pm Reply with quote
best to use masking tape, 2 runs, 1 for each edge. Then fill with an evenish bead of sealant. Wet finger with fairy liquid and smooth it off then pull masking tape up while still wet, don't touch it for few hours. Can get stuff called silicon eater from B&Q to remove old stuff but I would recommend cutting it out.
Back to top
 Alert Moderators
Scoby_Beasley
from United Kingdom
Thanked: 50 times
PostPosted: Sat May 08, 2004 11:14 pm Reply with quote
Am I unique that I don't have problems with silicone sealant icon_question.gif icon_wink.gif
Force the silicone into the gap by keeping the gun at an upright angle, get a piece of plastic/formica edging with the correct rad you require filed onto a corner with straight edges, run it along forcing the sealant in even tighter and wipe excess off your spreader with a cloth. Next day rub your finger over any thin films you've left behind to remove them (if you leave a thick film find a straight edge and score with a stanley blade first).
Voila, another good job done !!
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 2 times
PostPosted: Wed May 12, 2004 10:17 pm Reply with quote
Always apply the sealant away from you, i.e. push dont pull, and not too quick either. I confess though, it is a bit of an accquired art icon_biggrin.gif
Back to top
 Alert Moderators
Handyman
from United Kingdom
Thanked: 2 times
PostPosted: Fri May 14, 2004 7:14 pm Reply with quote
Scoby, what happens when your bit of formica hits a grout line in the tiles? Don't you get a little ridge in the silicon? In my experience, the only way of getting a good, clean, smooth fillet is using light finger pressure dipped in strong washing up liquid solution. And do it once only, 'cos as soon as you've done it the first time, additional silicon won't stick to the wet tiles.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
waterproof bathroom blind 5 8760 Thu Aug 26, 2004 1:08 pm
waterproof bath panel plinth 3 2560 Tue Dec 03, 2002 2:37 pm
waterproof ink 3 5860 Tue Aug 10, 2004 12:40 pm
How can I make a tiled shower wall waterproof 2 140 Tue Dec 13, 2011 9:25 pm
Re-applying Bathroom Silicone Sealant 3 120 Sat Feb 11, 2012 4:43 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
