DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Hotpoint DF61
This topic originated from the How to page called Dishwasher Troubleshooting
Click here to return to the page called Dishwasher Troubleshooting.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
ibbotsnm
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 20, 2007 8:39 pm    Post Subject:
Hotpoint DF61
Reply with quote Thanks
I would appreciate advise on how to remove the side covers of this machine. I have very good reason to suspect that the pump used for emptying the machine, is faulty. I have checked for blockages in the waste pipe, and that the one way valve is operating. However the impeller does not rotate. although it is not jammed with anything and is free to move.
By removing the two screws from the front edge of each side cover, they become loose but are apparently held in place by the top surface of the formica cover. There are no obvious fixings to this surface. I thought it might slide or hinge by means of the two plastic fixings at the rear. I am reluctant to force the issue in case I damage anything.
Any advise would be appreciated. Many thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
assuhors
from United Kingdom
Thanked: 3 times
PostPosted: Thu Jun 21, 2007 7:36 am    Post Subject:
press the latch upwards on underside back of lid and push lid backwards at the same time, one side at a time.
Back to top
 Alert Moderators
ibbotsnm
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 25, 2007 6:35 pm    Post Subject:
Hotpoint df61
Many thanks Assuhors. I did as you said. Very easy when you how.
Went on to discover that the impellor needed to be free'd up a bit. Have run it a good number of times and it empties well now.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Hotpoint DF61 not cleaning well 2 2400 Fri Nov 17, 2006 9:46 am
Hotpoint Aquarius DF61.... all noisey no worky 12 640 Tue Apr 14, 2009 6:27 pm
Hotpoint DF61 fill problem? 4 240 Thu Sep 17, 2009 12:19 pm
Hotpoint Aquarius DF61 - Top spray arm fell off 2 220 Mon May 11, 2009 5:17 pm
HOTPOINT WD64 WASHER/DRYER PROBLEM 4 400 Mon Aug 25, 2008 5:36 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
