Dear All,
I'd greatly appreciate advice about the following:
We've recently moved into a 1960s house, with an old GCH system with an old Potterton Kingfisher (over 30 years old) boiler and skirting rads in all rooms. The DHW (gravity system) and GCH feed pipes at the boiler are all 1.5 inch iron. The pipes feeding the rads are mainly 1 inch iron, although those feeding the bathroom rads are 1 inch copper. Its a 5 bed house, with about 13 rads in total.
There are a number of problems were getting with this system.
Firstly the gas consumption seems very high. From weekly meter readings its about 160KWh per day (or about £7 a day).
Secondly, when the heating is on, there's an almost continual clicking from the rads and the pipes (a real problem at night!). I think this is because of the design of the skirting rads, with lots of little metal fins around the main pipe) - see this pic:
The third problem is that the house never seems to get very warm. Admittedly we're not having the system on full blast - mainly because of reasons (1) and (2) above, but even so, the house feels really cold.
I'm therefore trying to get some quotes for replacing (or partially replacing) the system. In addition to general advice about these problems, there are 2 questions I'm wondering about:
1) Is it a problem to have a mixture of iron and copper pipes in the same GCH system? (i.e. electrolytic reactions, corrosion, etc?)
2) Will it be best to get all the central heating pipework replaced to modern copper pipes at the same time as replacing and resiting the boiler (with a powerful Valliant heatstoring condensing one) - or will it be fine to keep the old pipework and maybe replace the noisiest 1 or 2 of the old rads?
Any advice about this all would be really helpful,
thanks
Mike
thanks
Mike
