I have read so many posts here I thought it was time I wrote one.
I have a glow worm fuels saver F, open vented system, FE tank in loft, pump near immersion heater.
I have always had problems getting all the radiators hot in my house especially the 4 on the ground floor and the 1 in the basement. Recently I added de sludger and left it in for 10 days that drained the system from 3 drain points, and let cold water run through until it was clear. I then added inhibitor and limescale remover,but still its only the 4 rad upstairs that get hot.
I do have an immersion heater with a 3 way valve for hot water. There is also a stop cock type tap on one of the pipes near this 3 way valve. normally I have had it open, but last night I closed it and 2 of the rads on the ground floor went from cold to warm (not hot). Should this valve be open or shut.
Also I find I get a lot of hot water going into the FE tank, why is this.
I have my LSV's about a half turn open upstairs (where the pump is) and fully open downstairs (where the rads are cold)
Also I noticed the pump is not quite as quiet since I drained down
I have bled all rads and pump btw.
I have an boiler service due in 3 weeks, what questions should I ask the engineer. Im not convinced a powerflush is the answer should he recommend one.
Thanks Guys (and gals)
