Dirty and Clean Water in Heating System
26 Nov 2008
East Lothian
This is a sideline problem to another thread I have posted:
http://www.diynot.com/forums/viewtopic.php?p=1069461#1069461
Whilst we have been trying to sort the problem in the other thread we realised that three of of upstairs radiators.
My wife bled the radiators and noticed that the water which came out of two was pretty black and guncky. The third radiator was clean.
Whilst all three radiators are at the same elevation they may well be on a different pipe route. You have to go down half the stairs and then climb back up to get to the room with the third radiator.
Is this a problem which needs attention and if so what attention does it need?
if worried put some x400 in for a couple of weeks and then drain down a couple of times (having ran the heating for 30mins in between)..then x100
If you use X400 then leave it in for at least FOUR weeks!
If you want to do it quickly use X800 for about a day!
It sounds as if those rads are not being used as circulation would quickly equalise the distribution of dirt.
Tony
Tony
So if they have been part full of air for a long time (since say last January) that may have had an effect.
I leave the system to run for a new days and then check the water again.
Andy
