Bottom row of bath tiles
16 Feb 2006
Sussex
When tiling around a bath is it normal practice to fix the second row of tiles first (from batten) then when dry remove the batten and fix the bottom row?
The reason i ask is because i was wondering what you use to prevent the bottom tiles slipping down before the adhesive has dried.
Some do, some don't.
Er, the same thing(s) that you would use to stop them slipping down in any other scenario. I don't understand why you think that a batten is a solution to that problem. :?
I don't think you understand the question.
When the tiles above the batten have dried i will remove the batten and then fix the bottom course of tiles that butt up to the bath rim.
The rim of a bath is not as true and straight as a fixed batten therefore i doubt i can just rely on spacers to prevent the bottom tiles from slipping down and touching the bath before they have dried.
So what are those "same things" ??
I don't think you understand the answer.
Agreed. You'll have to use a variety of spacers, bits of card, bits of wood, and other household objects.
Please see above.
