Inverted Warm Flat Roof advice
23 Jun 2009
Norfolk
I am building a Garden room it is 6.5m x 4m block with cavity and I am now getting towards putting the roof onto it.
Have been researching different options of flat roof anf like the idea of the Inverted Warm Deck.
I am thinking of using a 1200g Polythene DPM that I used under the Floor Slab. Is there any reason why this would not be suitable?
Assuming that I can use it would it be ok if laid loose on my timber deck with insulation on top then a filtration layer then some concrete slabs on top.
Any idea how much I would need to Beef up the joists to cope with the extra weight?
Cheers.
Cheers.
I suggest you employ the services of an architect. Roof structures are complex in the extreme and if you get it wrong ... !
