P
Paul_C
Sorry, but it didn't, it stipulated ".....which may reasonably be expected to supply portable....."
Reasonable and likely are two different things.
O.K., I was paraphrasing. But "may reasonably be expected to" is certainly implying "likely to" rather than "capable of."
If there is either a weatherproof socket on the outside of the house, or a socket immediately inside the door, could it reasonably be expected that somebody would ignore those and instead run an extension lead through to some other room?
Maybe that is an example of an exception that proves the rule, what if there wasn't an outdoor socket? I would say on that there a lot of houses with gardens that don't have outdoor sockets.
That's where I'd say you could then reasonably expect that a socket adjacent or close to the door will be used. The problem with this rule in the 16th edition was that it was rather vague and open to individual interpretation.
The outdoor socket in your example, would require RCD protection anyway.
Agreed. But that doesn't mean that every other socket inside the house (on the ground floor) needs it.
Anyway, that's rather academic to the original query, since we now know that the upstairs sockets are RCD protected so the alterations would comply with the new 17th edition anyway.
OOI, do you know if the Building Regulations have been amended to refer to the 17th Edition?
AFAIK, the latest iteration of the SI refers specifically to BS 7671:2001, for example when defining the term "special location".
So far as I'm aware the actual Building Regulations don't refer to BS7671 at all, 2001 or 2008. There is reference to BS7671 in the "Approved Document," but even that acknowledges that there is no compulsion to follow BS7671, specifically citing other EU/EEA standards which would be taken as complying with the Building Regs. if followed.
But if I wanted to wire my house to American or Australian standards, there's nothing in the Building Regs. to stop me.
