VOKERA 24/96 RSE FLOWMATIC
1 Dec 2009
Yorkshire
This boiler was working fine until Sunday morning, and has now decided to lay down and die.
I have plenty of DIY experience, but have no intention of messing around with a complex boiler system. However I would be grateful for an indication of what the problem might be before calling an engineer.
Many thanks for any advice.
:lol:
The system has required a water top up every few weeks, and was low on pressure when it packed in. I had a look "under the bonnet" and found that a small leak was dripping water from the pump onto a component underneath, this has corroded.
This component has a wire loom entering it, and either two or three pipes, so I guess is a solenoid valve of some sort.
Many thanks kevplumb.
The wiring loom in question has three wires, brown black and white. The valve or whatever is connected to the water rather than gas system.
Is there any way I can check if this is the problem?
What a curious world we live in.
A guy from Yorkshire, UK, being helped by a guy from Tennessee,
United States of America.
not from just living there
born in hartlepool :wink:
if you can dismantle the cover from the switch and use a multimeter
you can test the switch
chances are its full of water
and turn the power off first :idea:
What's the weather like over there, its bloody freezing here at the mo.
sure fella :wink:
they are winging their way to you
on the back of
View media item 17066
