Hi all, I've got an old(-ish 1997) back boiler system that heats a tank of hot water by gravity and a pumped central heating system.
At the moment the HW system is on every time the CH system is on and as everything that uses hot water is electrical it heats up daily for no reason at all. I plan on replacing the copper tank with a new version that’s insulated to start with but I'd also like to get better control of the HW.
I've had a look online and frankly ended up more confused then before so can someone give me some basic info on what I need!
I have 5 pipes in total coming to/from the boiler, one is 15mm and is gas in, then I have a large 28mm going up, two 22mm's going up and one 22mm coming in from below. I've traced them up in the loft and the 28 and the lower 22 are the ones to and from the tank and the other 22's are the (retrofitted -fed from above) CH (I find it a bit weird that the pump is pumping down and into the boiler and not up and out but that's another question!)
I'm an electrical engineer so I'm quite happy to do the wiring myself and I'm happy to give the plumbing a go - I just don't quite understand what I need to buy and where it needs to go! I appreciate I could get someone out to do it but I enjoy a good DIY challenge
