Vokera Aqua Nova not working properly
1 May 2010
Derbyshire
My Vokera Aqua Nova water heater is not working properly: when I turn on a tap the water slowly gets hotter to about 45 deg C then goes cold then gets hotter and so on. I can hear a switch clicking in the unit as it is doing this. If I turn the tap off the unit's fan continues running for a while. No warning code is displayed i.e. the green light flashes throughout. The temperature control seems to make no difference.
The unit is about 3 years old and I don't think it has been serviced (I only just bought this house). I took it apart and cleaned out some dust but this made no difference. Burners look clean and clear (we run off an LPG tank) and so does the flue/fan assembly.
What is the light sequence on the front panel when it does that?
The Green light comes on continuously for a while, then goes back to on for one second, off for four seconds, then comes on continuously for a while, back to flashing, and so on. The Red light never comes on.
Solid green is burner on.
Flashing every 5 seconds is no demand.
Have you tried other taps? Are the taps fully open?
Yes, thanks, I read the manual and saw that this was the meaning of the lights. I've tried all 4 taps fully open, and the shower. The flow seems to be fine.
If flow is OK, have you checked the connections and voltage at the flow switch?
Take the wires off and check for a short crcuit.
I little thank you goes a long way too
