I have a Potterton Prima F50 boiler (SEDBUK Group G) which intermittently fails to ignite the main burner and just stays with the pilot light lit resulting in no hot water/heating sometimes in the mornings.
I have just been informed that I qualify for a Warmfront grant, an assessor has not yet been around but I thought it wise to do some research beforehand so I am prepared!
- As SWMBO wants a better shower performance
, I was looking at different options and someone has suggested that replacing my boiler with a “System Boiler” unvented with mains pressure could be a good option?
I’ve just read a number of threads on this site regarding Warmfront and Ideal boilers (so I won’t be touching them!
) and I will push for something better, possibly a Vaillant ecoTEC Plus 615/618? (are they okay?)
I have a 4 bed, 1 bathroom (bath/shower/wc/basin) + 1 en-suite (shower/wc/basin), kitchen, utility and D/S WC property. The CH system is vented with a 117l cylinder in the airing cupboard and two header tanks in the loft, 2 x two port valves (allowing independent HW and CH) and pump. I replaced the standard room thermostat with a Danfoss TP7000 programmable one a few years ago, I’ve 11 rad’s but none have TRVs.
We are looking for a replacement that is economical to run, gives a good shower performance, as we have two young boys must be capable of handling ‘family use’ i.e. Washing machine / dishwasher being used during the day, baths for the kids and showers for parents in the morning.
I guess my questions are:
1) Is it a lot of work to change from a vented to unvented system plumbing wise? (the header tanks are located directly above the cylinder in the loft, the boiler is located on the wall in utility room)
2) Is a Warmfront grant (£3,500) likely to cover the costs for changing to a unvented system and do their rules allow it? (are they more efficient?)
3) Alternatively should I consider a high kWH combi boiler i.e. Vaillant ecoTEC Plus 837 with has a flow rate of 15.2 l/m
With a budget of £3500, what would you suggest is my best option for a replacement boiler/CH system?
LN.
LN.
