kingspan insulation
Yes, Cant see why not to be honest, T/O may be best because if you pour it may go in between the gaps of the boards, But i'm sure that wont matter, Not much should seep through.
do not under any circumstances torch straight onto insulation boards without having a 3B layer of felt down or you will burn the place down.
All it is i have factory roof to do and can get a quantity of kingspan insulation cheap and it looks like coolag so wondering if its defo compatible with bitumin?Ill prob be using pour and roll as coolag releases gas(kingspan looks very much like coolag?) and without pur glass you get blisters,so will be vapour bar,insulation(kingspan?) pur glass/underlay all fixed with hot stuff and t/o cap sheet.Only thing is i need to know 100% if kingspan compatable?has anyone ever used it in this way?I can get foil backed or plain?
Apparantly you cannot use kingspan cavity wall insulation with hot bitumin/torch on,you must use the stuff designed for roofs :cry: well thats what i priced for anyway i was just hoping to save a few quid but its no good if the jobs not going to be right.Thanks for the input. :wink:
You were going to use the Kingspan cavity insulation?!! :shock:
You need the one with 6mm ply already bonded to it, The Kingspan TR31.
You should know this having 30 yrs exp surely? lol
I'm sure you would have passed your saving onto the client. :wink: :wink:
Nope,fixed price labour/materials all in,just like if the job takes 2 months instead of one the price will be the same.Would have been nice to have got the insulation for a third of the price but if sumin sounds too good to be true it usually is.
