hi
my bosch WVD24520 is playing up
problems
when put on a dry cycle the drum fills with water and I get the F18 error
when put on a washing cycle it stops at the spin cycle and just turns slowly with 1 minute showing on the time left until you turn it of
if you put it directly on to a spin cycle it spins no problem
what i have tried
checked for blockage in filter and hoses
have seen the impeller spinning while attatched to the machine on spin cycle
have made impeller spin connected to a lead direct to power
checked impeller is tight on shaft
checked pressure switch clicks and that tubes are attatched
any pointers would be greatly received as this machine was nearly £500 and is only 2 months out of warranty
many thanks mark
problems
what i have tried
many thanks mark
