Looking on the net i see this is a common problem with this machine, however i cannot find a thermostat trip switch or sure where the filters are if anyone has any advice on this please post
filter is at the back remove rear white panel its a big black cup . no themo cutout whats the fault with the heating .
Check the heater is working first it's on the heater box.
heater is the two brass round nuts on the heater box with a blue wire and pink one attacted to it.remove the two wires off the heater and test .filter is as pic a big black cup looking thing with a fat jubilee clip round it if the mc emptys ok that will not cause it to not heat ,the heater you got on that mc go all the time also check the themal fuse its the pink wire with a yellow cover round it test with a continuity tester.
http://cgi.ebay.co.uk/HOTPOINT-Washer-Dryer-WD-Heater-ELEMENT-Genuine-Spares-/370337145162?pt=UK_Home_Garden_Washing_Machines_Dryers_Parts_Accessories_ET EASY TO REPLACE UNDO NUTS, 6 BOLTS ON HEATER BOX, THEN 8 BOLTS TO SPLIT HEATER BOX .
no its a diffent heater ,found at the back next to the filter.
