does anyone know how to remove the transponder from around the ignition switch ?
You don't need to remove the aerial ring from around the ignition barrel. You need to change your e.c.u, and put the matching transponder chip in the ignition key. No need to change the ignition barrel, only the chip in the key.
The company have supplied a complete kit. If you bought a television, would you need to get on the roof and change the aerial ??
You're missing the point. When you buy a kit of ANYTHING, there are parts supplied that you don't necessarily need as you might have these already. I recently had the pump changed on my central heating. The guy removed the new pump from the housing it came with, as I already have a housing plumbed into my system. He just put the new pump onto this housing. Therefore I did not need the new housing. If you look at Vauxhall ignition barrels from about "N" reg onwards (1995/6). you will see that they're marked "I", "II", "III". Just before the first "I", there is a white dot. This indicates that the vehicle is fitted with a transponder sysytem, and therefore it already has an aerial around the ignition barrel, so it does not need the aerial that was supplied in the kit. Hope this clears it up now.
