Potterton Promax Combi 28 HE Plus
3 Nov 2010
Newcastle upon Tyne
Our boiler has recently started to ignore its instructions from the wireless control. It comes on at different times and generally stays on, only stopping when switched off via the central control on the front panel. We've changed the batteries twice in the remote and reset the boiler a few times with no change. I've checked the pressure and that's fine, operating within the green zone (1.0 to 2.5). It's just over three years old and has been great so far. Any ideas and suggestions as to can be wrong and a fix gratefully accepted. Many thanks.
Hi Robimac just wondering did you get this sorted because i have the same problem any help would be gratefully appreciated regards Allan
Hi Allan, in the end I replaced the timer controller (the remote unit and communicatons unit on the boiler) very easy to do and cost about £110. Had no problems with it since. The new unit is different to the old one and it seems it is a known fault. Hope that helps. BR Rob
