I had planned to get an Ecotec 428 installed to replace an ageing conventional boiler. However having read many discussions yesterday on code S.53 I am having second thoughts.
It looks as if the problem is the 428 heat exchanger that creates a high pressure drop and so the minimum flow is often not reached. This means that my relatively new Selectric 15-50 pump will need replacing.
The system is Y plan with a conventional open vent cylinder.
I also planned to fit a VRC430f and VR65 with the VR10 installed on the cylinder.
Is this set-up going to be more trouble than it's worth?
