Hi, I havn't really posted on here much before but I use I reguarly use it for solutions, however i'm now struggling on specific information about my new Programmable Thermostat.
We've got a Potterton Suprema 40 boiler (i think thats the name) with a Danfoss CP725 programmer, and up until now, a Danfoss RMT230 room thermostat. Our RMT230 wasn't working correctly so i decided to replace it and wanted something more advanced, i was advised a Timeguard Programastat TRT035. After a load of hassle yesterday we finally got it working. Not 100% sure it's correct but it turns the heating off below the temperature and on about the set temperature.
Anyway, the problem is that I set the heating and water times on my programmer which I assumed was correct. Apparently not. When the programmer is set to 'off', then the thermostat will start the boiler when the temperature falls below the set temperature, but when the programmer is 'on', then the radiators are heating up regardless of the air temperature around the thermostat.
I appreciate I probably don't have a full understanding of the system, but it seems that one scenario is contradicting the other. Could someone please shed some light on how the system should work, and what what I should set my programmer too so it works properly.
(NOTE: I can't set the heating and water times separately on the programmer however I can set them to on/off/auto/allday separately)
Thanks in advance
Thanks in advance
