I've done something wrong as i've got the same leak on the 2 rads i've just fitted !
The 2 rads have Bulldog thermo valves and the leak on both is where the 1/2 tail screws into the rad itself. I've put ptfe tape around it a you should but both weep slightly . It's the first time i've fitted rads and valves and tbh i was a little supprised how far in the tail went before it sarted to tighten up
Is it just bad luck and a little more tape required or am i missing something ?
Thanks.
Thanks.
