need some help pls..
after my last post "positive isolation" got me thinking
say if am cheaking for a short between the main live an neutral to the programmer boiler etc but what about thigs with relays like three port vlvs & programmers
i would have to check the switch lives also i guess
Help my head is up my a**e now!!
This is a point I bring up again and again when people talk about PAT testing. Central heating, Washers, Even freezers have timers and thermostats which only connect some items for a short time.
Where twin pole relays are used the only method of testing involves some dismantling. But most items only switch the line so testing neutral to earth will in many cases highlight faults even when the de-frost element, motorised valve, empting pump etc are not energised.
The other problem is earth wires on printed circuits. Many PAT testers draw 25 A to test the earth and this can burn out the earth track on a printed circuit.
Already mentioned the 500 v used for insulation testing can also cause problems. However since the item should be disconnected from supply before testing so there is no link between neutral and earth on many items 500 v earth to neutral or earth to live will not cause a problem. Except where there are EMC filters on supply.
So with electronic items one has to be careful and using 200ma for earth continuity and 230 v for insulation resistance is a wise move.
But to test any equipment one has to know what it has inside and if it is regarded as IT equipment or not. And the PAT testing course I did was far too short to teach non electrical people how to safely test "In service electrical equipment" without damaging the odd appliance from time to time.
Even an electric drill has a speed control which is electronic. Vacuum cleaners have EMC filters and other than the standard lamp one questions what one can use 500 volt with out risk of damage.
For an electrician to do a test and write out the procedure and then for a semi-skilled to follow the laid down tests is OK. But to expect non electricians to test must mean you will also expect to replace things
