I see Boone's table has 2.5mm rated at 18.5A (lowest) in a wall and 30A free (highest). So, I would assume a mixture of the two (most free under floors) would be around 25A per 2.5mm cable.
The 25A current when passing through the area of 18.5A installation would overheat that section of the cable as the heat produced in the copper could not be disapated from the outer surface of the cable
Stop trying to justify wiring a 20A oven onto a ring circuit.
