Unfortunately, after 6 years of "contributing" you've failed to notice that this is a DIY forum (it says so at the top of the screen) and operates primarily for the benefit of amateurs.
You seem incapable of grasping the central point: that your oft repeated advice: "improve your technique until you're as good as a professional" (otherwise stated as "I'm brilliant") is about as useful to other people as a kick in the crutch!
Joe - this has nothing to do with techniques, the product helps with coverage and a wet edge witch is definitely needed with these WB paints! No one has been using them long enough to be an expert with them!
On a separate note anyone been using blue lid Dulux ... Apparently they have solved the yellowing and just generally made it better? I hope so im not happy with all this change!!
Yeah but - Joe`s daughter got to uni - and my son`s just a spread But he`s 4th generation building tradesperson . I wonder in the fullness of time who will have the biggest house - Excluding parental help
