Aquarius WMF540.
6 Dec 2011
Hi all,
Machine 32 months old. Used lightly with light loads.
On start the pump works immediately, no water in and motor does not turn at all. Temp light shows cold and pressing temp button does not change temp lights.
After approx 1 minute fault code F-01 comes up and all 5 lights flash continiously.
I've checked brushes visually and they seem perfect with little wear.
It has mk4 board and this seems as new with no corrosion, also Cap17 looks as new with no swelling.
Any ideas most welcome,
Thanks all,
Roberto101.
If you know which one it is , I just replace the pcb. Speak to emw in Nottingham they do recon pcbs they might tell you which one it is.
