Remove the rest of the fireplace?
11 Nov 2011
Derbyshire
Hi All,
Wanted some advice please..
I've knocked the front off the fireplace wanted to know if i should take the brick out as well.. there seems to be a surrounding where i have taken the plaster off. would like to take it all back make the room bigger..
All so any ideas what the hole in the floor was used for? a bit of a draft coming through it.
Cheers
[/img]
It would be intresting to know!
First time Ihave seen it.
can you go a floor below and see where it goes?
Maybe it was just a route of disposing burnt coal stuff?
Hi Ibby
There is no basement, it is a little cottage in derbyshire, i have never seen it before, i dug down a bit it has brick around it but has been filled with rubble by somebody..
I thought it might be a coal storage? be nice to hear if anyone has seen this before?
do you think i could remove the brick and take it back?... i am not sure if this was a later edition.
Cheers cotswoldbuilders,
would they of lit the fire over it to draw the air through it?
do you know by the image if i could remove the brick... would it be a large fireplace originally?
If the fireplace has been bricked up to hold a smaller fire,
shine a light up their and check.
If it gets wider, it was bigger.
Have a look up the opening and see whats above the insert brick opening, I would have thought the small brick opening has been added afterwards, it would look a lot nicer opened up to the original opening.
You would have a fire grate above the air intake, might even be a plate to slide over to control the air flow.
there were a couple of pieces of metal been put in the air intake.. which i thought might be a some sort of lid to it..
thanks for your advice... i have had a look up and it is wider as you said i think it would look much better to... the brick does not look great!
i'll knock it out and lets see... fingers crossed hey :)
Cheers
