Hi folks,
need some advice on the best fitting to use here on these CH pipes. (It's the feed or return pipe)
I've removed the old soldred tee and the horizontal pipe, but the vertical one is really confined. You can just get a couple of fingers betwen it and the soil pipe, less space than it looks in the pic..!) The old soldered tee was leaking from 2 joins in the tee after pipes moved around when fitting boiler. The guy did a solder over the old join but it's leaking again since I did some more plumbing to powerflush the system and tidy up the pipes over the boiler. Hardly moved it but I think his fix was a bit of a temporary job really as he never replaced the fitting. So I reckoned removing the old tee was the best option and fitting a new one.
I've sand papered it and steel wooled it as best i can but don't want to heat too much cos it's really confined next to plastic soil pipe and a joist that I've charred a good bit already just getting the old tee off (yes I used a heat mat but it took a LOT of heating to get the top join off...)
(By the way the scoring in the bottom pipe wasn't me sanding it, it was like that already, maybe from the pipe cutter originally??)
I think a solder join would work best but I'm no expert at this at all and feel given the space and risk it's not worth me trying to solder.
Quesiton is I've got a cuprofit push fit tee, do you think that would take to the old pipe folks? (I'm not sure it would, but anyone know how they take to an imperfect pipe??)
Opinions on push fit tee to those pipes?? Or any other option.
(Given it will be behind the wall when the plaster board is put back too...!)
Failing that I might get a plumber in to solder cos in the confined space not worth me learning. (I used to be a good gas welder but discovered soldering copper pipes has to be learned just like gas welding had to be...!)
Thanks folks.
PS system is not pressured, it's open vented regular boiler...
Thanks folks.
