Hi guys
So I am planning on fitting a shower enclosure/tray (See link below). As you can see from the picture the tray is on the ground, there appears to be no base whatsoever and I am wondering how on earth one goes about installing something like this ? I have a drain above the ground and can only see it working if I build a foundation. The other alternative it to drill into the ground and have the drain under the surface. Any thoughts/recommendations/suggestions appreciated- Thanks.
http://www.diy.com/nav/rooms/bathro...el-H-190-W-120-D-80cm-10567894?skuId=11058578
