Ideal isar HE30 L9 error
8 Mar 2011
Leeds
Yep I have one of these monsters.
It wont fire up and shows an error code L9
Help needed.
Tia
Taz
Ok, just fired up for about 20 seconds and steam started to come out, just below the dry fire thermistor kit.
Pressure looks fine.
Can't feel if the pump is turning.
probably your pump thats knackered then!
I have been told to put a small screwdriver in to the pump to see if the impellor(?) moves freely and it may(miracles can happen)free it up.
Is this correct and if so how/where do you place the screwdriver?
There are 2 types of pump on an ideal isar.
one has a brass screw on the front which you can take out then insert a flat screwdriver into the hole and check the rotation of the pump.
The other type has a black plastic cover that you can unscrew and check the rotation of the pump.
Obviously you need the boiler to be calling for heat, you will soon know if the pump is running.
Ok, looks like a new pump is needed(as you suggested)
Million $ question........how easy are they to replace?
Can you/anyone advise on the correct procedure please.
Ok.........I will try another question.
I have now removed the pump.
Can I test the pump by wiring it up without bolting it back onto the boiler. Can I fire the boiler up for a few seconds to see if the pump rotates etc.?
Best to power the pump from a mains socket with a 3A fuse.
Saves damaging your boiler any more!
Why not read what to do it the site FAQ? Then you can do the finger test!
Tony
are you sure the last part of this sentence is correct
The steam came out from joint/bolt where the heat engine meets the burner kit.
Sorry if the terminology isn't quite right I am using the Ideal parts diagram to identify the parts.
