Just had a new Vaillant Eco Tech Plus 630 boiler fitted and the heating engineer has set the flow temp at 60 degrees from the boiler. Have 3 manifolds, 10 loops, all with adjustable mixing valves to control the mixed underfloor and under screed zones. The old boiler didn't have a programmable flow temperature, set with an adjustable dial. Having searched various subjects on this forum could I have your opinions on:
1) It is more efficient to leave the UFH heating on 24 / 7. I have set it up to run from 04.00 to 20.00.
2) Can the flow temperature be decreased - does making the return temperature lower make the boiler more efficient
3) I have bled the manifolds twice and removed quite a bit of air - fine yesterday afterwards as the system was running at around 1.1 bar. However not running overnight, I assume the cooling water has dropped the pressure, as a result the boiler had switched itself off this morning, it was at 0.3 bar. Topped up the boiler a little and running again at 1.5 bar. Is it trial and error to reach the correct pressure
4) Any other tips.
4) Any other tips.
