Due to issues with the boiler I've had to use the immersion heater for the first time since I moved into the house. But it got far too hot. When I took the cover off the power cable was wired directly to the element and bypassed the thermostat. There is still a metal link from the thermostat to the element but both wires just go to the element.
I don't know if this is a bodge because the thermostat doesn't work or just someone messed up, the previous owner wasn't the type to do it herself so someone must have done it for her. Can I test the thermostat with a multimeter for continuity? When I adjust the dial it clicks so something seems to be working.
Plus what size wire would I need to replace the cable? The current one is quite tight and if the thermostat is different to the one in there now the solid metal link won't fit so I'll need replace it with some wire and there is no spare.
