No hot water - very old system
6 Jan 2013
Down
Hi
I moved into an old farmhouse about a month ago. The central heating is fine (but heavy on oil), but doesn't heat the water very well, so I've been having to use the immersion heater or electric shower.
I've had a look at some of the other posts about this topic, but they all seem to refer to heating that was fine, then stopped heating the water. I don't know when this system last heated the water :? I've had a look at the cylinder, but couldn't find any kind of thermostat - unless they're sometimes not obvious. Surely, even an ancient system should have some kind of thermostat on the tank, but maybe I just don't know exactly what I'm looking for.
All help would be appreciated.
Samantha
Have you any red wheeled valves (gate valves) inside your airing cupboard?
Some of the older systems just used the boiler thermostat to control the temperature.
Hi
Thanks for the reply.
Yes, there's a red wheeled valve on one of the pipes near the cylinder in the airing cupboard.
Samantha
