Hi Everyone, I am hoping for some advice. I am currently redoing my bathroom in my new house and have an issue with the water pressure to the shower. The hot water is the std gravity fed system with the hot water tank in the airing cupboard next to the shower. The header tank is in the loft about 4-5 meters about HW cylinder. Hot water outlet from cylinder is 22mm for at 6inches then into 15mm. I have tried different 'low pressure shower heads' but water pressure is still poor. In my previous house I had the same set up except the HW outlet from cylinder was 22mm all the way up into loft and over to shower drop down then 15mm and the header tank was larger in size.
Can someone give advice on whether the size of the pipework or the header tank is the problem?
Many thanks
Many thanks
