Hi there !
I am new to the site and have found it very helpful.
A while ago my boiler which is very old (a glow-worm fuel saver) started making some very loud noises and just didn't want to start. since then i have trawled the net looking for answers. first thing i did was take all the rads off and hosed them out and it was really dirty. all back on the wall and bled them to get the air out. that did nothing really. then a guy i met through e bay who is a gas engineer said he would pop by and have a look (nice chap) had a look about and told me that the pump and valve needed replacing. (it's a three way hollywell and the pump is a grundfos) so picked both up on e bay both new. money is very tight so i wanted to learn something and maybe save some cash. (oh and for good measure a new thermostat) as that does not seem to work either but never really used it. that was a pain to get off !!! so were the rest. blood sweat and tears later it has all its new bits on and there were no leaks
i rained the system and put some sentianlx400 in f+e tank. and turned the whole system back on and did all the rads afterwards. fired it up and yes you guessed it. boiler still making loud noises (banging and clunky noises) and after about 30 secs the flames went out followed by more noises. it wont fire back up for ten mins or so. i have tried looking at a few different things too. pump valve etc but all in good working order. the pump was originally up side down too. so i put it back that way and still the same. i have changed it so the flow is going up as per the manual and still the same things happening. both tanks in the loft are full. i think the f+e tank looks a bit too full. about 3 quarters of the way up. it might be blocked i guess but i have flushed it through 3 times already. i have had a good look on the forums and have tried a lot of the little things but still a no go. really don't want to call a plumber so any help would be gratefully received. i did the wiring on the pump and i don't think it's that. my dads an electrician and said it seems fine. taps are spluttering now and then still. sorry it's long winded but just trying to give you all the info.i will try and post some pics to help. ( not sure how to get the images up just yet)
