Hi
We want to make our loft a usable room and at the moment there is no insulation (or ventilation) in the roof space at all. We are however, getting a couple of Velux windows fitted this week.
I understand we should have 100mm (fibreglass wool) insulation between rafters then 170 horizontally across that, but I am really confused about the 25 or 50mm air gap I've read about!!
We're in Scotland so there's no roof felt - the tiles are just attached onto butted sark (?) boards held up by rafters.
The 1920's/30's bungalow is quite prone to damp so I don't want to cause any additional problems. How on earth do you create this gap? Loft is very big so I don't fancy adding multiple battens to every single rafter cavity! Surely a batten would block airflow anyway?? I also don't want vents in every single cavity either - there would be hundreds and it would look awful outside.
I've also considered using only the YBS super quilt over the rafters but I don't know if this would be warm enough. Does anyone know the equivalent depth in comparison to traditional style?
Any advice would be much appreciated!
