Recently had cause to drain the system for decorating purposes, which I've done a few times before without problem. However when I refilled the system, even though I stopped filling long before the pressure gauge reached 1 bar and bled the air from the radiators, the pressure kept rising (slowly) until it was over 2 bars.
I should note that on previous occasions there has been a delayed pressure rise, which is why I stop filling at about 0.5 bars anyway and wait for things to settle, draining off extra if necessary. This time, however, I have drained and bled the whole system and the gauge still reads about 2.
Is it likely to be a faulty gauge or is there some kind of localised pressure build-up?
BTW. I'm not planning on filling it again/testing it until somebody qualified looks at it (unless there's an obvious, easy solution), I'd just like to understand a little more first.
