Fan continuously running.
1 Oct 2008
Lincolnshire
I have s Vokera Compact 25HE combi boiler and the fan occasionally gets stuck on and wont stop unless I turn a tap on then off again. The burner is not on whilst the fan is running.
Does anybody know if it's an easy diy fix by maybe just cleaning a sensor, if not would it probably be an expensive job?
Thanks all
Not safe to change just relay. And it is a GAS SAFE TECHNICIAN only job....not DIY.
If left, it was soon simply constantly run on and you'll be stuck.
From your name I assume you're gas safe?
If so, crack on with the solder iron.
