or that's what the window fitting firm told me when they came round to investigate!
I have a upvc, half glass, door fitted in our kitchen which leads into a small lean to porch which is single glazed and has a wooden single half glazed door.
To shut our kitchen door, when you first push it to, it catches on the frame so you have to lean on it and give it a little shove with your hip to get it to shut well enough to engage the lock. It got steadily worse over about 6 months, and the window firm came out and adjusted the hinges which improved it but they told me that it was because it was creating a vacuum with the porch. They also said because we'd had building work done that there was probably dust in the mechanism and to try some WD40 ...
Since then, it's got worse again, and some of the trim around our other windows is lifting away and there are drafts coming in. These windows and doors are now a year old.
Is the guy right and what should I do please?
