Hello there, this is my first post.
I came home from 3 weeks away, to find some of the lights in the house weren't working. I also found that the fridge was off, and had completely defrosted (I had to throw away absolutely everything). Long story short, after trying lots of different things, this is what I know:
- If I try to switch the RCD on (pushing it all the way up), it instantly trips (I can feel the tripping action as I reach the top).
- If I turn off the big red switch (Main Switch), the RCD will stay on (the indicator turns red and stays red). As soon as I turn on the Main Switch, the RCD trips. This happens regardless of whether the RCD Protected MCBs (the green ones, Nos. 9-12) are on or off. In fact, with every single MCB off (Nos. 1-5 and 9-12), as soon as I turn the Main Switch on, the RCD trips.
- If I switch the Cooker MCB (No. 9) on, and then switch the RCD on, the Cooker MCB trips with a loud pop and a visible spark (it's dark under the stairs where the CU is), and the RCD trips instantly.
- The cooker doesn't have its own switch in the kitchen. I pulled the cooker partially out, and there is a thick cable coming out the back of the cooker, and snaking away under the cabinets, which I assume goes directly to the CU.
- The cooker is a Kenwood Type C9T, Model CK 404 (gas hob with electric ignition, and dual electric ovens).
- The only things that work in the house are: lights everywhere, 1st floor sockets (for some reason they are not RCD protected). Things that don't work: anything in the kitchen (lights do work), sockets on ground and 2nd floors. In summary: all lights work, and sockets on 1st floor work. Nothing else works.
- I'm currently running an extension from a 1st floor socket to power the fridge + jug or microwave or dishwasher (only one at a time).
I'd really appreciate any feedback. I've read a few posts that imply that damp gets into the oven elements, possibly due to the house being empty for an extended period.
The main question I have: assuming the cooker is at fault, is it logical that the RCD won't stay on even when the cooker MCB is off?
Thanks in advance!
Thanks in advance!
