- Joined
- 18 Mar 2008
- Messages
- 1,491
- Reaction score
- 1,090
- Country
Re-reading my description of current hot water heating it might look as if it is cycling - its not
The heating comes on strong(you can hear a nice roar) until it gets to 85/6 then you can here the heating back off a little but still on until temp drops to 81ish then comes on strong again - it repeats this until it stops but never cycles even at the end.
Given that the hot water is now not cycling with it set to 20 and it seems ot heat up well - would I be right in thinking I can leave alone?
Unfortunately I have no idea where the VR10 has gone or why it was not fitted in the first place or even if there are enough free wires in the cable run from the cylinders back to the boiler!
The boiler is due a service though - how can I find some one around TW19 who is as knowledgeable as you guys?
Thank you both so much for all the help!
I wondered if you meant it was cycling, but good it's not! The 'correct' setting of D.77 is when the boiler modulates (goes quieter) at the end of the reheating cycle as it nears the desired temperature. 20kw sounds about right then, maybe try raising it to 22Kw, it may shave off a couple of minutes. If you find its on/off cycling at anytime, back it off a couple of KW and leave it there.
The quicker you can reheat the cylinders, the sooner the heating comes back on
