I have a chalet and have an electrician installing an off grid solar system. He's told me to design and supply everything I want and he's going to fit. He fits grid tie but hasn't done an off grid.
I've got
2 x sharp 250w panels
1 x hybrid 4000w off grid inverter with charge controller
PIP4048HS is a 4000w continuous / 8000w surge, 48V DC input Pure Sine Wave inverter-charger featuring:
NEW - max 60A Utility Charging
NEW - total system max charging: 110A (50A solar + 60A utility)
Built-in 50A PWM solar charger
2X Surge rating up to 5 sec
Generator Starter Dry Contact
4 x 105ah batteries
1 x garage type consumer unit
There will be a small AC circuit and a DC for the lighting and a couple of cigarette skt.
I have a few questions
What fuses and or disconnects should I be buying?
Would I be able to run a single electric oven on that?
Do these hybrid inverters make any noise does anyone know?
Would there be any reason not to install all of the components in a plastic keter type shed outside the chalet?
Trying to use as little on gas as possible.. Help appreciated. [/b][/i]
I've got
4 x 105ah batteries
