Greetings all, I'm looking for some advice and suggestions.
I've got a Keston C55, manufactured in 2006, which has been running the house central heating successfully for about seven or eight years.
I know that Kestons are at best a dark art and usually the boiler that everyone loves to hate, but this one has done ok so far.
The recent problem that has emerged is that the boiler fires but doesn't run for more than a few minutes, claiming it's up to temperature.
The display shows the operational mode and the flow temperature, and the sequence is thus:
1. Switch on demand for heat.
2. Boiler enters A mode as it takes some internal readings.
3. Boiler enters 1 mode and spins up the fan to full chat as it runs the preignition sequence.
4. Boiler enters 2 mode for ignition and sparks up with a nice woof.
5. Boiler enters 3 mode and starts heating water like a champ. The flow temperature rises from 13 up to about 19 in about five or ten seconds, then the fan throttles right back, seemingly to an idle mode. The water temperature creeps up ever so slowly and the flue doesn't get hot to the touch at all. It does this for about four or five minutes then...
6. Boiler enters 6 mode. Burner not running as the boiler is up to temperature.
Now, once thing I can't fault this boiler on is it's ability to throw wobblers spawning error codes. If the thermistors go short circuit it should report it. If the thermistors go open circuit it should report it. If the temperature differential is too high or too low, it should report it. If there's flue overheat it should report it. If there's an ignition problem, etc. etc. The diagnostics are really good.
What's troubling me is that there are no error codes at all.
The boiler runs CH only, with no DHW requirement. It runs off the top thermostat, which the boiler knows is set to 62. I've set the redundant stat to the same temperature as well, just in case.
It knows the flow temperature is 22. It seems rather like the boiler is behaving exactly as it should, apart from the fact that it's about forty degrees too cold! Why on earth does it think that it's up to temperature?
At the moment I'm just trying to understand the mechanisms at work. Can anyone shed any light on what part of the process might be going wrong, or has anyone encountered similar problems.
Thanks in advance.
Thanks in advance.
