having failed to find a pre made bathtub that is the design I need (tub shaped but with a step at one end, because it's sunk into the floor), I'm thinking to form it in situ using concrete. Any tips what additives and design considerations I'd need? What sort of thickness do you think for the walls and base? Would it take a mix of grey and white cement, swirled to add some effect, or would this introduce weakness? Would reinforcement of some kind be required ? And what of finishing the surface.. Is it enough to polish it, or should some sealant be applied?
